Discuss Would HIVE work with this oil boiler and controls? in the Central Heating Forum area at PlumbersForums.net
Hi All
Please see attached photos. Does anyone know if the HIVE app and thermostat and control would work with this oil boiler plse? The thermostat control ( Honeywell) is restrictive as you have little options as to when you can have boiler on and off. It's my elderly father's boiler and I want to be able to access the heating control remotely so he has heating on!
Cheers
Betty
Yes will require a bit of reworking / wiring but yes
Reply to Would HIVE work with this oil boiler and controls? in the Central Heating Forum area at PlumbersForums.net
Hi all. So I have just moved into a new house with a Potterton boiler in it. Great big thing!! lol. I want to fit a Hive to it but it obviously...
1K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I...
I am considering replacing my existing boiler with the new 2023 Vaillant ecotec plus 625 boiler. I currently have 3 x Heatmiser neoStat...
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I...
