Weighing down bath before siliconing
View the thread, titled "Weighing down bath before siliconing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
I have a bath to silicone that I can fill with water before I silicone. Can I put some some weights or something in the bath to mimic the weight of a bath full of water. Anyone had to do this before?
The best way to weigh down the bath before you seal round the bath to the tile, is to half fill the bath with water, wait until the sealant has dried then empty the bath. Use a decent quality sealant, job done.
I need to silicone before I fit the taps. Guess I can swap the waste. Fill bath. Then silicone then swap the taps
You can weight it down, but make sure whatever you put in the bath will not damage it, eg: sand bags or other heavy but soft items, baths can easily scratch, so if you have to use heavy hard items, then put a large dust sheet or similar inside first to protect the bath. Cheers
Was thinking maybe pillows then some weights on top of those if I need to
Reply to the thread, titled "Weighing down bath before siliconing" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Matt0029,
