Water inside a PRV gauge.
View the thread, titled "Water inside a PRV gauge." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Noticed this today, no visible sign of leak from the gauge externally but leaking or has leaked internally as you can see.
Will ask my plumber to replace the gauge but is this at risk of leaking / bursting with water coming out of it?
It looks like part of the water meter fit. You should get in touch with the Anglian Water Service if you have a problem with thier gear. They should check it and if it is faulty they will replace it for free.
If you get a standard plumber to touch it both you and the plumber will be in big trouble from the water board.
Hope this helps.
Reply to the thread, titled "Water inside a PRV gauge." which is posted in UK Plumbers Forums on Plumbers Forums.
techweb,
techweb,
