Well I've managed to run into a bit of a pickle by cutting out some old pipework in the loft and realising nothing I had would fit on to the old 1/2" copper pipe up there. Long story short (happy to add details if anyone's interested), I got the sinking feeling when the solder fittings I had wouldn't fit on, so tried compression and couldn't even get the nut on, let alone the olive. Won't go all the way into a Speedfit either.
Just to be clear this isn't the regular 1/2 which is more or less the same OD, and nor will it go on with a bit of a shove, it's not even close to fitting. Measured with calipers, it's about 15.5mm OD.
I've tried buying a bunch of 15 to 1/2 adapters but they mostly just seem like overpriced 15mm couplers, some are marginally bigger on the inch side measured with calipers (like 15.1mm) but still not close to fitting.
Looking around online I've seen references to 'council copper' or 'rhodesian copper' from pre-1970's era which is entirely possible given the age of the property, but I've not really found a proper solution.
Options I've found which seem reasonable but unsure of:
Annealing and swaging the pipe (assuming swaging such a thick walled pipe could be... fun, in the cramped working area)
Philmac UTC coupler (seems possibly best option but not sure if it's suitable for internal use?)
John Guest NC471 (I have one, but not convinced it's the correct size, seems possibly too big, not sure exact dimensions it's designed for).
Any advice would be very much appreciated.
Thanks for reading!
Thanks for reading!
