100KW gas boiler for domestic install!
View the thread, titled "100KW gas boiler for domestic install!" which is posted in Boiler Advice Forum on UK Plumbers Forums.
100kw is massive, can't imagine you'd need that size! I wouldn't want to go for a combi with that size house mind. Unvented system would do the job!
was it this one,😳 Is some one else getting kw and btu mixed up again hopefully they will not get as far as hanging it to the wall.
haha nice pic, where do people get theese figures from, with a larger house with system boilers i'd watch the expansion vessel, we normally fit heat only boilers for larger properties, that being one of the reasons.
See my pics for examples aswell.
Right I have been to house and measured the rads. All are Quinn double convector details listed below. Need 34KW to drive the rads so not 100KW. Can anyone recommend a boiler with correct capacity?
Cheers
[TABLE="width: 347"]
[TR]
[TD]Rad Size[/TD]
[TD]Power[/TD]
[TD]Number[/TD]
[TD]Total[/TD]
[/TR]
[TR]
[TD]1800x600[/TD]
[TD="align: right"]3497[/TD]
[TD="align: right"]1[/TD]
[/TR]
[TR]
[TD]1400x600[/TD]
[TD="align: right"]2720[/TD]
[TD="align: right"]6[/TD]
[TD="align: right"]16320[/TD]
[/TR]
[TR]
[TD]1200x600[/TD]
[TD="align: right"]2332[/TD]
[TD="align: right"]3[/TD]
[TD="align: right"]6996[/TD]
[/TR]
[TR]
[TD]1100x600[/TD]
[TD="align: right"]2137[/TD]
[/TR]
[TR]
[TD]1000x600[/TD]
[TD="align: right"]1943[/TD]
[/TR]
[TR]
[TD]800x600[/TD]
[TD="align: right"]1554[/TD]
[/TR]
[TR]
[TD]700x600[/TD]
[TD="align: right"]1360[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD="align: right"]14[/TD]
[TD="align: right"]33807[/TD]
[/TR]
[/TABLE]
Cheers
[TR]
[TD]Rad Size[/TD]
[TD]Power[/TD]
[TD]Number[/TD]
[TD]Total[/TD]
[/TR]
[TR]
[TD]1800x600[/TD]
[/TR]
[TR]
[TD]1400x600[/TD]
[/TR]
[TR]
[TD]1200x600[/TD]
[/TR]
[TR]
[TD]1100x600[/TD]
[/TR]
[TR]
[TD]1000x600[/TD]
[/TR]
[TR]
[TD]800x600[/TD]
[/TR]
[TR]
[TD]700x600[/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Advertise on the section of the forum saying I'm looking for gas engineer/plumber wanted. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/[/DLMURL][/B] and get a decent guy down . bin the current guy.
I spoke to engineer today to say about 34kw load so why such a large boiler and he said he had a TSM from Worcester attending site tomorrow. I didn't know they had such a service so I called Worcester and they do indeed have such a service. I spoke to technical pre-sales asking for an opinion or insight and they said they couldn't give definite answers without seeing everything.
One thing they did mention is heat loss in the pipe work if the lengths are long.
Can this be so bad that it needs a lot of extra power in the boiler to compensate?
Do all the rads go on one loop?
Any insight or suggestions gratefully appreciated.
Cheers
Just forget this guy ever mentioned 100kw. It's now irrelevant. I think I'd be looking for a new installer tbh.
You will only need a 100kw boiler if you intend to turn the house into a marajuana factory to supply your whole town
Get someone else in to suss it out, very rule of thumb is 2.5-3.5 kw per room ( this allows for variables of room size) as a quick calculation, so a 100kw will do about 30 rooms haha
As suggested go with a system boiler and unvented cylinder you won't regret it
How come you two seem to be experts in growing weed?
No wonder you're both such chilled characters. Roll us a duuuuuby!! LOL.
I've never tried it, but I've been in 100's of houses where they were smoking it, and one many years ago in a multi storey flat in Glasgow which we got called out to in the middle of the night flooding flats below, police got called to attend for forced entry and the whole flat was full of ants, with a 10" gap path to walk round the whole place, the heat lamps were rigged of the power for the lift and the temp was sky high, as soon as the joiner opened the door the smell hit us and the cop radio 'd in for the drug squad, brilliant engineering and workmanship to set it up haha
Don't mention the Lambo it's away back and now I'm bored and invisible I'm my XF Jaguar haha
Well I'm not getting into the thorny subjects of drugs, and what we've tried or haven't.
Suffice to say that a nice cold beer is the only inebriation I like. Or scotch, or brandy, or wine, turps.....the list goes on!!
But you don't know if the radiators are correctly sized?
Use the Whole House Boiler Size Calculator to find out what size boiler is required.
It does not matter if the radiators add up to more; it just means they can run at a lower temperature.
Worked out what house requires previously and size, volume and construction need 32kw. Rads output 34kw.
Worcester TSM has been to house today to talk to engineer and he has said it needs a 65KW boiler and a U16. I am trying to get the contact details for the worcester TSM so he can explain his thinking.
What the hell?
I implore you, please get another heating engineer round. This stinks. Even if you do it on a Saturday and just pay him to specify the system for you.
Most will add 10% to each rad/room when sizing rads, which explains the discrepancy you've found.
Again, get a new engineer!
A 40CDI should be fine. I recently fitted a 40CDI regular on a house with 31 rads. The whole house heating calc came to just over 37KW and it works perfectly well and is in no way undersized from an output perspective!
I don't think you need a light commercial boiler for what you have... 40KW domestic is fine
Absolute horse sh 1 t if you need 65 kw you have a swimming pool to heat also, I specialise in larger properties and from the info you have given no way!
Earlier you said that you had used several online calculators and could only get to approx 25kW. Which one did you use to get the 32kW?
Used whole house boiler sizing method which came out at 23kw Calculated Boiler Size
Used heat loss calculator to work out how much power required for each room and that came out at 23KW Trademate by City Plumbing Supplies
I also used [DLMURL="http://www.theradiatorcompany.co.uk/heatoutput/"]Radiator Heat Output Calculator and size calculator - The Radiator Company UK[/DLMURL] to see what radiator output was required for each room. Got the output for each room, added up and total was 24KW
Not sure if needed to add 2KW for HW so have added just in case which brings it up to 25-26KW
The 34 KW figure comes from using the radiator manufacturers technical data. I have looked up the output of each rad installed and the total out of all rads is 34KW.
Head spinning now :-( Have asked another installer to come to house and take a look.
In from cold has keen confused - 100,00 btu not 100KW 30 kw will do his place
on a system boiler set up. 100kw will light up over 1600 60 watt light bulbs
- old type !!!!!!!!!! or 100 1 bar lecky fires
Hi All
New member and first post.
I'm not in the trade so hoping folks on here with all the knowledge can assist.
Got 5 bed detached Victorian house that has no central heating so in process of getting boiler and rads spec'd.
Have been told that will need a 100kw boiler and that this boiler will need a a larger gas supply pipe even though there is 22mm already.
Was hoping for a combi as there is only one bathroom with shower over bath.
Room sizes (in metres) are listed below, All double glazed with solid walls but I calculate heat requirement at 25KW so where the 100KW comes from I have no idea hence this post. All the on-line calculators I have used are all coming in around 25 - 26 KW for heating.
Hope someone can help or offer advice. I would think 100KW is large enough for a school or factory or a 5 bed with 14/15 rads.
Cheers
Room H, W, D
Living Room 3.1, 5.49, 4.88
Sitting Room 3.1, 4.22, 3.91
Dining Room 3.1, 3.23, 3.12
Kitchen 3.1, 5.18, 4.47
Bed 1 3.1, 4.42, 3.2
Bed 2 3.1, 4.42, 2.29
Bed 3 3.1, 7.21, 3.56
Bed 4 3.1, 3.86, 3.23
Bed 5 3.1, 4.27, 4.11
Bath 3.1, 4.42, 3
Reply to the thread, titled "100KW gas boiler for domestic install!" which is posted in Boiler Advice Forum on Plumbers Forums.
infromthecold,
infromthecold,
