T
TBServices
Most will add 10% to each rad/room when sizing rads, which explains the discrepancy you've found.
Again, get a new engineer!
Worked out what house requires previously and size, volume and construction need 32kw. Rads output 34kw.
Worcester TSM has been to house today to talk to engineer and he has said it needs a 65KW boiler and a U16. I am trying to get the contact details for the worcester TSM so he can explain his thinking.
Earlier you said that you had used several online calculators and could only get to approx 25kW. Which one did you use to get the 32kW?Worked out what house requires previously and size, volume and construction need 32kw. Rads output 34kw.
Four pages in and we're still nowhere.
/exits stage left.
Hi All
New member and first post.
I'm not in the trade so hoping folks on here with all the knowledge can assist.
Got 5 bed detached Victorian house that has no central heating so in process of getting boiler and rads spec'd.
Have been told that will need a 100kw boiler and that this boiler will need a a larger gas supply pipe even though there is 22mm already.
Was hoping for a combi as there is only one bathroom with shower over bath.
Room sizes (in metres) are listed below, All double glazed with solid walls but I calculate heat requirement at 25KW so where the 100KW comes from I have no idea hence this post. All the on-line calculators I have used are all coming in around 25 - 26 KW for heating.
Hope someone can help or offer advice. I would think 100KW is large enough for a school or factory or a 5 bed with 14/15 rads.
Cheers
Room H, W, D
Living Room 3.1, 5.49, 4.88
Sitting Room 3.1, 4.22, 3.91
Dining Room 3.1, 3.23, 3.12
Kitchen 3.1, 5.18, 4.47
Bed 1 3.1, 4.42, 3.2
Bed 2 3.1, 4.42, 2.29
Bed 3 3.1, 7.21, 3.56
Bed 4 3.1, 3.86, 3.23
Bed 5 3.1, 4.27, 4.11
Bath 3.1, 4.42, 3
HiIn from cold has keen confused - 100,00 btu not 100KW 30 kw will do his place
on a system boiler set up. 100kw will light up over 1600 60 watt light bulbs
- old type !!!!!!!!!! or 100 1 bar lecky fires
You said earlier that you were considering a combi boiler as you had only one bathroom/shower. Is this still the case?Used whole house boiler sizing method which came out at 23kw
Hi
That's exactly what I thought but installer and now worcester TSM have said that not the case. So, with all the advice from everyone on here and my initial concerns I have another instaler scheduled to survey.
I am amazed that a representative of the manufacturer can give such poor advice :-(
so you could thank us all talk to the organ grinders not the monkeys
