2 Keston C40's
View the thread, titled "2 Keston C40's" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Good Morning - Flue's for Keston C40. Where can I get them from ? I have the flu bits up to the 2inches sticking out of the top with hte grills on. I need now to extend them sothey go outside. They are 75mm wide. The keston docs say 'marley', can someone tell me where I can get the 4 flue's (2 boilers) from please ?
Finally for the humour of you plumbers. I do have the cylinders as well. and the pipework in the house is done. \
The plumber who was goign to work on it, is very ill so i'm still looking for a plumber and its november. I have all the parts for everything I believe now, I just need 1) Gas Registered person, and 2), plumb er to connect the cylinders to the boilers and the pipework. (Suffolk/Leiston/IP16.
White waste pipe. That was one thing Kestons made a big point of when they came out that you could use ordinary plastic drain pipe for flues. Did a commercial job in an old folks home with 100mm grey soil pipe.
Hi, can someone tell me where I can get flues for the keston c40's, i been told they 50mm. i need 4, and they need to just go directly out the same wall the frame the kestons are connected to . So I dont think more than a few inches is required.
any pointers greatly appreciated.
Thank you.
Michael
Oh - Re Plumbers.... They say they come in 3's.... Today I now have 3 called all saying they can start tuesday (odd!). but I'm happy. They just asked me to get the flues, so they can come in and do everything straight way unless they get it, but they said they would do it cost.
you are right, it does need a professional.
blame the plumber who went into prison and stole the equipment,a nd the thieves, who stoll the copper piping, and the 'manager' who spent the othe rmoney that was left.... i've come back a few years from my breakdown to stand up and face this task .
Fingers cross, and I'm really hoping it will work. (they seen my bank balances plunge).
So the plumber went to prison, then stole the equipment while he was in there? Schocking.
As for the 50mm 'flue pipe', you can get them from any plumbers merchants. Just go in and ask for 50mm waste pipe. But to be honest, why not let the plumber you select to do the job buy it? You say they have all agreed to supply it at 'cost', so what have you got to loose?
We're getting there.
my friend has got the heating working without the boilers, tested all the cold, hot tap water to all taps (by heating a cylinder with its heating element) and has put a separate cold feed through the central heating (separate cold from the cylinder cold of course) and heating pipes. Using just the low loss, cylinders and we have now mains, cold, hot water to taps, and cold water heating (yes, it tests the water), so now we have proven all pipework is fine (where builders hadnt screwed screws through the pipework, and radiators had not been put on properly.). We have left one cylinder on heating the hot water in taps, so bingo we have showers and baths and taps all hot.
So the next piece of this saga is now that my friend is now looking at how to wire up the the 2 c40's with the cylinders and low loss header, he says everything all there now. (i've bought everything). All pipework now we understand and now we are looking at wiring it up.
Does anyone know of any 'diagrams', other than in the installation and servicing instructions on setting up the c40's together?. I'd like to see if there is even someone who has either in suffolk/essex/london/kent/surrey (I can get to any of these places) to come and see an already installed setup that we can look at as a reference point or would be patient enough to tell us on the phone or over a beer how to set it up?
My friend is pretty confident that everything will work and is completent with normal systems but this is quite a big installation for him and needs advice on how it all fits together. Once all done we will get the gas engineer to complete his task.
S plan
Been a while... but thank you for the S plan. We now have both keston c40's working and i got a spare one i collected yesterday for spare parts.... we now have hot water and central heating. although the central heating is not heating the whole house. we are pressure testing and cleaning the pipes and radiators. as a few of the downstairs radiators are 'black' inside.
so now we looking for a decent coupel of pumps for the 40mm central heating and the 2 zones for the hot water.
Have a look at dab
Also FYI you can't repair any gas appliances unless your gas safe
Reply to the thread, titled "2 Keston C40's" which is posted in UK Plumbers Forums on Plumbers Forums.
j0mpst0rt,
ShaunCorbs,
