R
realstokebloke
I have a Salamander S flange to fit onto my HWC (mainly as i got a Salamander pump & so then, they can't moan if something goes base over apex).
So i took the vent pipe off the top, ready to screw on the female / female brass socket (as supplied) but it was obviously way too tight from the off & i was in danger of stripping the thread, so i put it all back to investigate.
Very glad i did, as it seems i have a Gledhill (?) HWC - which are the 'only' ones (i'm told) to use 22mm on the male out at the top - the rest of the world uses 1" (i'm told).
So...my Q is: has anyone ever come across a similar socket female / female (about 35mm deep) that has the corresponding threads: 22mm @ the base & 1" @ the top?
(And no, i really don't fancy plan B - replacing the cylinder).
Failing one of those, i understand all top entry flanges are 1", so would my only solution be to get an Essex boss instead?
Sure it's something someone has come across before.
Many thanks.
Many thanks.
