had a 28cdi with hot water not coming on, customer has to turn tap on and off a few times to get it going.
tested the micro switch all ok, so decided to take the diverter valve out and replace diaphragm with a service kit, got everything out and the diaphragm is is shot to pieces (happy days) as i was about to replace it i notice the spindle on the diaphragm was shorter than the one i took out, went back to the van and found another kit which was the same length.
got everything back together and was quite happy that i was going to turn the tap on and have lovely hot water......... but nothing!
the spindle is still not coming out far enough to make the micro switch. so after all that work ive ended up sticking a washer to the end of the spindle cap, which has solved the problem but its a bodge and probably wont last that long.
the flow rate was good the diaphragm and spring are in the right way around, so i was just wondering if anyone else has come across this or knows of anything else it might be,
also just to note the customer has always had a problem with the DHW and has had to mess about with the taps to get it to come on. she has lived at the address for 15 years
any help would be appreciated
cheers
cheers
