View the thread, titled "3 - channel RF programmer. Anyone know of one?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Masood
Hi all,
Been asked to convert a system to 2 heating zones (easy enough to get to pipework), but with HW it's going to be a S+ plan with 3 zones. I know Horstmann do 3 and 4 channel programmers, but not RF. I can't lift floors, etc to run new cables, so need a RF solution.
Thanks,
Masood
Need more info? Are u doing it in airing cupboard ? Can u get wire from zv to wiring center??
I would say install single zone controller ( hw ) then two rf programmers for ch? Ch receivers can go by zv. Use the common s/l to send back to boiler?
That is plan B! 🙂 - 2 x programmable room stats and a single-channel programmer for HW.
Plan C is Horstmann 3-channel prog, 2 x RF room stats with receivers wired in to programmer...
Install in cupboard. Wiring centre, boiler, cylinder all in same location. Preference for 3-channel programmer is to fit in same location and same size as existing programmer, otherwise wallpaper will have a hole in it.
Have Drayton not brought out a new thing called mitime. Found link [DLMURL]http://www.draytoncontrols.co.uk/WorkArea/DownloadAsset.aspx?id=33050[/DLMURL] is that what your after?
Reply to the thread, titled "3 - channel RF programmer. Anyone know of one?" which is posted in UK Plumbers Forums on Electricians Forums.
