View the thread, titled "3 Port Valve why?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
At this time you tend to want to see/feel/hear what's going on ... Some heat is better than none at all I guess 🙂
Issue could lie with circulation ... Do the radiators get hot top to bottom? I never feel the top of a radiator as an indicator of how well a system is working 🙂
Well at least you have the warmth sorted. As for the rads have you tried to give the radiators a bleeding through, see if the same thing persists. Was this happening beforehand????
Engineer just been, after the burner has been on a while it cuts out at temp as it should but fails to fire up again, the pilot sparks but no gas until it cools down.
He said he will return in the morning and replace the gas valve / solenoid
Sounds like the PCB going has taken out the gas valve, some older boiler were bad for that double whammy 🙁
ive just started with social housing work i was a bit worried i wouldnt be up to speed turns out most of them know less than me
went to a bunderous which was stuck in hot water mode obvious realy as theres a great big tap lit up in the display previous engineer had ordered a new pump despite the fact the boiler was producing hot water with out any problems problem
I'm sure this company are Ok, very nice on the phone 24hrs but it's probably pot luck on the engineer you get. The first one was useless but todays was great.
Smells like british gas! Didn't flog you manga filter?
When he returns go through the alphabet with him.
A b c d e f g h i j k l m n o P q r S t u v w x y z
See what i did there. ??
Sorry I don't understand what you mean by APS.
The bloke that sorted it today and came back after i discovered a further problem was very clued up just like you lot, I did tell the company to never send me the first bloke again, life's to short
Will let you know if his diagnosis of Gas valve sorts it for good tomorrow
Oh mate its worst than waiting for a long bus.. I'm trying to keep up. What make is the combi boiler again...?? really I shouldnt be asking as I'm not gas safe yet...
This is a double wammy or a wouble dammy experience ..
OH MAN NN.NNNN.
Can't wait for the final of the year.. sounds amazinga..
Oh my I have absolutely no idea what you are going on about, I was just keeping the engineers that helped in previous posts updated as I appreciated them sharing their knowledge. I've obviously took this too far and will leave it at that.
Thank you
Sorry memo, it's just that after sixty odd posts on a topic our attention wanes.
I'm sure that your proper engineer will sort it out.
Bear in mind though that even the best is fallible and may need another attempt.
Sorry about the fuss I'll keep up. But after All.. put this in the new year resolution for 2014 it's close
Would you have an old Switchmaster diverter valve? If so the motor could have stopped working between the hot water and heating function therefore not sending a switch live back to the boiler.
British gas serviced one of my boilers I fitted 2 years ago last week! The engineer recommended a magna booster to the customer... Even tho there is a shiny new magnaclean below the boiler, with magnaclean sticker on case of boiler...only british gas would getaway with this.... Disgusting!
Reply to the thread, titled "3 Port Valve why?" which is posted in UK Plumbers Forums on Plumbers Forums.
