StevenW
Hi guys,
Recently moved into our house (old 50s police house,4 bed) Been slowly working our way through the previous owners bodge work throughout the house.
Now trying to make heads or tails of he heating system..
The house was extended about 10 or 15 years ago and I think the setup is a bit of a mish mash of the previous system and new.
Its a pressurised, S plan layout system. There is 4 pumps in total.
- 1 on flow out of boiler
- 1 for the downstairs UFH setup.
- 1 on upstairs radiator flow pipe
- 1 on DHW coil in tank.
There is only 1 zone valve on the entire system, on the flow to the upstairs rads, just after the pump.
There is also by-pass loops, one next to both the up rads supply pump and the DHW pump. However one has a gate valve fitted (partially open) and one is just a straight loop from feed to return, with nothing in between. Seems wasteful to me?
There is also NRVs fitted on the output side of the upstairs rads pump and also one on the input side of the DHW pump.
Any help, advice, or even a basic diagram would be fantastic. Seems a bit overkill having a pump on each 'zone', fair enough on the UFH but not the others.
and not having a 2 port motorised valve on 3 of the zones seems wrong, and getting a lot of heat soak into other areas when not needed.
Have a feeling the NRVs could be left over items from a previous heating setup in the past.
Hope the photos work!
cheers
Steve :santa3:
cheers
Steve :santa3:
