Jul 26, 2017
Scotland
DIY or Homeowner
Hi folks, I'm new to the forums and looking for a wee bit of advice. Having recently bought a new home I've found a leak under the sink which needs repaired.
I have a 40mm PVC waste pipe going from the sink into a 110mm cast iron stack, which is packed with what I think is Plumbers Mate or something similar which is very soft and pliable (see photos):
Advice from the guy in a local plumbers merchant is to dig out the sealant and repack it with Plumbers Mate, Putty or even silicone 😱 ...is there any other simpler solution, like some kind of reducer to connect the cast to the PVC?
Any help is greatly appreciated 🙂
There will be a piece of copper or lead into that cast iron with the plastic connector onto it. I bet the condensate from the boiler hasn't helped.
If that's 40mm plastic, then it's not 4" internal cast, it'll be 2.5 / 3 as Shaun said.
The collar on the cast is about 15mm thick.
You may end up using something like this, sizes would need confirming first over the outside of the cast;
Fernco Adaptor Coupling 112-102 / 45-38mm Grey | Priority Plumbing
