48kw domestic boiler
View the thread, titled "48kw domestic boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
B
Blueflame
hi all, just been to a quote and need to replace a standard conventional flue boiler with an up to date gas condensing boiler.
It needs to be around 48kw, my quails are domestic only. I know I can work on up to 35mm gas, dependant on volume, and 70kw rated input.
Is there a manufacturer out there that produces a 48kw heat only boiler?
Or will I have to cascade two boilers.
thanks in advance.
As per first post my quals are domestic only, so need a domestic boiler.
I assume I am right in thinking a boiler from the commercial range must be fitted by a commercially qualified installer?
Commercial must be fitted by commercial.
How big is the place to need that much heating? Must be massive
its actually a church with meeting rooms, currently fitted is a 45kw free standing, asbestos flued, cast iron lump which was condemned this week so they need a fast turn around.
I do work for a few of the committee members so have been asked to submit a quote.
I'm assuming they have a u16 meter and adequate pipe work.
If they do have a u16 you cannot go very far with 35mm. A u16 alone is 0.025m3
I would say that the Keston c55 will prob be the best thou.
And depending on pump sizes you have there at the moment and flow rates. You may be better off using a low loss header so as not to affect the flow and saves you having to buy another pump if the one that they has does the job
[FONT=Tahoma, Calibri, Verdana, Geneva, sans-serif]
Simon what does a low loss header actually do? Something I've been wanting to ask for ages, apologies if that seems like an ametuerish question. [/FONT]
A low loss header allows a system to work when you need to pump high pressures
A boiler has a resistance of how much water can be pumped through and how fast
Say you have a rugby pitch that needs to be heated. If you were to put a worcester 28ijunior. It may have enough kw to heat the pitch but the pump will prob struggle and burn out within a day
So you use a low loss
You have a small 15-50 in boiler
That heats low loss header
Then a Grundfos magna 40-120 to circulate around the pitch.
The water is all the same. A low loss is just connects the two systems.
Have a look at this pic
http://www.flickr.com/photos/magicfoundry/1764196037/
Atouchofgas. Com property does not mean its commercial. It comes down to Iv meter size and appliance.
I look after a house with a Strebel ca-7s does that mean a domestic eng can service it?
Fantastic explanation, believe it or not I've actually fitted a couple with buderus boilers as was advised. But i like understanding things but never got around to finding out what exactly they did. Thanks!
You can also use the to have different circuits using different temps
So one rad system with 80c water
Hws circuit 65c water and
UHF circuit 45c
Having 3 circuits coming off llh and 3 port mixing valves controlled by controllers to mix the water temps down
Simonjohns, I know what your saying, just that's what I was taught when doing commercial training. I was told its buried in the regs some where
Reply to the thread, titled "48kw domestic boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Blueflame,
Atouchofgas,
