cr0ft
3,311
1,782
113
Lincoln, Lincolnshire
Heating Engineer (Has GSR)
Hi all. Proper spotter question this one. Anyone know where I can get a standard panel radiator with 570mm pipe centres? Thanks!
You may be able to get away with a 500 rad and two rad valves with the 3/4 union connector on??
500 rad, when i first fix i allow 45mm either side for valves (Danfos Ras C2 are the valves i use) so that gets you 590 and the valves will knock in a bit so might get that, if not slight offset one side?
L
UK Plumbers Forums
Deleted member 120897
