Evening chaps,
A customer of mine has put a nail through a 6mm heating pipe.
It's in a notched joist that holds about 8 other pipes just before they all bend down into the manifold, the other direction goes under a laminate floor so not a lot of room to work in the spaghetti junction that I have to repair tomorrow.
I'm thinking that cutting out a section and renewing with couplers will be a pain, don't really fancy disturbing the other pipes any more than I have to with it being so close to the compression fittings to the manifold.
I had a craaaaazy idea :6:
Will 8mm pipe, or 10mm pipe have a close enough internal diameter to solder a length sleeved over the damaged 6mm pipe?
I was thinking of cutting the 6mm where it is slightly more accessible and feeding a larger diameter copper pipe over the nail hole and the cut I made if you get what I mean? Then soldering both ends of the new larger diameter pipe as if it was one big slip coupling.
Has anyone done anything similar?
Oh, and this will mean I don't have to buy a 10m roll of 6mm that I will probably never use aswell as some stupidly priced 6mm couplers.
Cheers.
Cheers.
