Hi, has you plumber in cylinder/boiler? could a blow off/discharge pipe be dripping?. ive seen new pressure relief valves drip.
Oh, come on,read the whole thread, please
You may have seen pressure relief valves drip, but this isnt happening here
Hah, you lazy bugger, I posted that all earlier, just a cold tap in the bath, cold tap in the HB and the WC (which is isolated and dry)
From valve no 3, there are 2 elbows, soldered, 1 pulled bend, 1 straight pushfit connector, 1 T which goes off to the bath, the T then goes off to the HB, then finishes with a soldered elbow to the WC which has an isolation valve on it, which is off
EVERY joint has tissue round it, which when I left on Saturday was dry
I have to leave the water on, a bloke is living in the Granny flat
I'm a lazy bugger am I?
I'm just trying to help you out
sort it out your self pxxxk
Soldered joints then pushfit did you put in continuity bonding where you broke line with plastic and I'm lazy muppet
Yes, if you had read the thread from the start, you would have seen where the leak is supposed to be (the pipe JUST feeding the bathroom) the reason a push fit was used, was the pipe was near a timber joist and I didnt want it catching fire (I got a limited amount of space under the floor
No I havent put in bonding yet, I will do that when the leak is sorted, what is the point in putting on bonding if the pipe has to be changed ?
If I could sort it myself, I wouldnt be asking in here would I ?
I been a plumber for 40 years and have never had this before, has anyone else ?
I was calling you lazy in jest (I couldnt find a smiley face) sorry if you took offense
Derrick, does the customer know the problems your having? If not and your sure you cant find a leak then best just finish up and go. Although thats easier said than done. I would say your best bet is to do what has already been suggested and pressure test your section of pipe after valve 3. Try and get a good nights kip without thinking about it to much and let us know the outcome tomorrow.
Oh, he knows, by god does he know, but his reply is, I want it sorted,
I'm on a price plus parts, so makes no difference to him how long I'm there, I cant finish off, I have to connect the kitchen up, then try and get paid (cant see him doing that if the meter is still going round)
So until tomorrow, when I get the gauge and test the pipe that the suspect leak is on, there is buggerall I can do
Thanks to all for your replies and suggestions, they really have been appreciated, if I have ruffled anyone up the wrong way, I apologise, no offense was intended
Look there is a leak somewhere after 3rd valve it might be small and going somewhere you can't see might not be your fault it could be a pin hole in pipe up might just be better roping it out and doing it again if that the easiest way
After this pressure test, that has got to be the next move, I'm hoping the tissue I have round every joint is going to be wet, at least I will know then and do something about it
It is brand new copper at the monent, do I run it in poly or more copper ?
I hope you get it sorted let me know how you get on
I'll be letting EVERYONE know, I would hate anyone to have to deal with something like this again
Should have gone for an hourly rate, would have paid for Christmas somewhere sunny
If you can check all the pipe as it probably not your joints as you already checked them it's a hard one mate I do feel for you
If you change whether poly or copper it's your choice personaly I prefer copper
But nothing wrong with plastic it has it's place
We live and learn mate
After 40 years I thought I had seen it all, but this has me beat
I prefer copper, sweated joints myself, usually regard plastic and pushfit as a DIY thing (but the fittings are handy in tight spots or a loft with old style lagging (inflammable)
Interesting...
long shot and I'm sure its been ruled out all ready, I have read all the threads quickly (six pages) so my apologies in advance... Mixer tap body allowing cold into hot water side of life? as I say a long shot
I use all all sorts in right place
Copper
polypipe
Loads of underfloor pipe
Pipe in pipe
But will always prefer copper
Interesting...
mmmm, havent thought of that, but the cold tap in the bath has been off and not dripping into the container I have wired on tto the spout
