A real brain teaser, its got me beat
View the thread, titled "A real brain teaser, its got me beat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Derrick229
Hi Lads,
Just been replumbing a house, they said they had a leak
They had a new main put in by 3 Valleys, great, no problem (no leaks)
They have a granny flat next door, and a valve that isolates the granny flat and the hotwater (this line feeds the combi boiler (it also isolates the hot water to EVERY WHERE)
I have run a new line to the bathroom, it feeds just the bath, hand basin and toilet
So is it clear so far ?
1st valve, isolates the whole place (main S/C)
2nd valve isolates the cold water in the granny flat, the hot water to the WHOLE house, the kitchen in the house and the outside tap
3rd valve isolates just the bathroom
Are you still with me ?
When I isolate the main valve (no 1) the water meter stops (this tells me that between the water meter and the main S/c is fine, no leaks)
I now shut off the 2nd valve which shuts off the granny flat, kitchen, outside tap and the hot water supply from the combi (the main valve is now open, of course)
With the main valve open and no 2 closed, I open no 3 valve (which feeds JUST the bathroom), no taps are open or dripping in the bathroom, the ball valve isnt letting by
BUT the meter is still going round, now common sense tells me that somewhere there is a leak, so there is going to be a damp patch or a puddle
There is nothing, the taps arent leaking, the pipework is dry, I can see all the pipework
I called the 3 valleys guy out, even he saw it, meter working, no damp patches, no dripping taps, dry pipe
Anyone got any ideas what the hell is happening, I been told by the 3 valleys guy the meter only works when there is a flow of water,
It only seems to be when the valve (no 3) that feeds the bathroom there is a flow, I cant find it
Anyone any ideas, because its got me buggered, 3 valleys are reluctant to dig the meter up, they say its fine (and as the leak is AFTER the meter, its the house owners problem)
(I have to be really honest, I think there is a fault on the meter)
Huh, there are only 3 valves there,
main SC, no 1,
granny flat no 2,
bathroom number no 3
So what do you mean all 3 with 1 open ?
could be a toilet overflowing!!!!!! also check that any tanks or cisterns are full before you look at the meter
Is there (or has there been) an outside tap or watering system?
Is there a heating pipe leak and valve 3 supplying the F&E tank as well as bathroom?
Nope as I said the BV is fine, not dripping, nothing from the overflow
There are no tanks anywhere, all mains fed
re read it Derrick he said shut off valve 3 and put valve 1 on
Ah, right, there is nothing, the meter isnt running (and no water from the H/B, bath and WC) and this is with no 2 shut as well (which supplies the hot water)
If you can imagine a T, with the main S/c at the bottom, on the left is S/c no 2 on the right is S/C no 3,
All within 18 inches of each other
The cold feed to the bathroom is S/c no 3, pipe is going up the wall and is exposed (I pulled a bend to get above the ceiling) then picked up a push fit conector, then a T to feed the bath, then went on to supply the hand basin and WC
The pipe is dry and as far as I can see no damp patches, no drips, I isolated the WC, just in case that B/V was dripping, it wasnt, which just left the HB and bath on
Now if anyone can suss this out,I'll buy em a few pints, no matter where you are
Nope, as I said, the outside tap is fed by BV no 2, along with the cold supply to the boiler (the pressure in the boiler isnt dropping either, on the heating side)
I think you will need to go back to the beginning.
Isolate and pressure test each part of the system.
You are getting a leak somewhere
That I know, according to the meter, but I have wrapped EVERY joint with clean dry tissue, they are all dry, the pipe is exposed
It is all up to mains pressure, which is at the moment minimum of 1 bar
If you joints are OK.Assuming that the No 3 valve was already fitted, could you have disturbed other existing joints connected to pipe lengths that you have worked on?
I installed no 2 and no 3 valves, ran new copper to the bathroom and to the bath
How did they work out they had a leak? Were they just looking at the meter when they saw it going round?
Logically a fault on the metre would occur continuously wouldn't it? Since you can make it run with one valve rather than another there must be a leak. If you can't see it that doesn't mean it's not there. You must have failed to check something. Painstaking, lengthy search needed. Is all pipework surface? Surely some must be hidden.
They saw the meter was working (they were having a new kitchen moved and fitted anyway) even when no 2 valve to the granny flat was isolated, I put in a new valve no 3 and no 2 valve (they just had a ballfix valve fitted) and ran new pipe to the bathroom
1, the pipe is exposed, but at some point it will be behind plaster board
2, I open valve no 1 and have both valves 2 and 3 open, meter runs, close valve 2, meter still runs, close valve 2, open valve 3, meter runs, close valve 3 meter stops, open valve 3, taps shut, BV in WC closed, meter runs, tissue round every joint dry, now no puddles, no damp patches, all pipe visible
How much of a search can I do ? it has gone on for some time now, I have put in new pipe, now logic tells me if there is a leak, there will be some kind of a sign, but there isnt anything
hi
i was wondering if u shut the 2nd and 3rd valve and left valve one open, is the water meter still ticking over if so valve to mite be shot if its a ballafix its comman or bs 1010 then then new washer or dodge jumper letting water through. just a thought from a unexprinced plumber. 🙂
hi
With no 1 open and no 2 and no 3 shut, no the meter dont move (there is only 18 inches seperating all 3 valves)
All valves are brand new (they are stopcocks, not ballfix valves)
Any replies are appreciated
Hi Derek-Has the toilet sistern got a conventional overflow onit or is it one of those that if you get an overflow situation it connects into the toilet and goes down the soil stack ? if its the 2nd one it may be overflowing into the toilet without you noticing it.
One of the first things I checked, conventional BV, with a isolation vale (I shut that off) but the over flow goes out on to a flat roof, not leaks there or wet spots
Have you bent the pipe anywhere?
Daft I know, but, some 30 years ago I fitted a new kitchen. New pipe leaked. There was a pinhole in a brand new length of copper pipe. If you had a bad piece of pipe and put a bend on it it could just leak at that point. Just a thought. Anyone else ever had a bad piece of pipe??
right you will have to ; open all 3 valves to pressurise the system , then close valve 1 and monitor the pressure in the system if it drops you have defo got a leak then once that is established its a case of doing each one seperate untill you track it down.
Only bend I pulled was to get it in the ceiling from the kitchen into the bathroom (the boards are up) I then put in a pushfit connector, then a short to pick up a T to supply the bath, then from the other end of the T to pick up the HB and WC
But even with a pinhole, there would be some sign of it, ie water puddle, damp patch
How fast is the meter going round when only valves 1 & 3 are open, I would have thought if it is a drip type leak then you would not notice the meter moving by eye but only over a period of time. Cane you close valve 3 and open valve 2 and then some tap and try and replicate the meter speed to give an idea as to what sort of volume we are talking about. In addition where do you live? There may be a member that lives nearby who could pop round and give a second opinion.
Hah, not daft, done all that
I can confirm that when no 1 is open and no 2, there are NO leaks (the meter dont move)
When no 1 is open and no 3 is open, the taps are shut, the BV is shut, the meter turns, but no water shows anywhere, my tissue paper on each joint is dry
Tomorrow, when I go back, I will be disconnecting the bath/HB/WC and putting a cap on all 3, then turning on the No 1 valve, then I will know that the taps and BV arent leaking
Apart from changing the new pipe I have put in, there is nothing else I can think of
I have had 2 blokes I used to work with come round (not including the 3 valleys bloke) they are as snooked as everyone here, they have done everything suggested here and the same thing I have done
The meter moves slowly, not sure how to measure how much of a flow though
WHEN i had a temporary meter fitted last month as I thought there might be a water leak I found out that there wasn't - a natural spring in the garden.
I asked the waterboard engineer how sensitive the meters were. He said ' set a tap dripping and have a look'. I set a kitchen tap dripping at about a drip every 4 seconds and we could see the little star shaped wheel quiver as it very slowly moved. Obviously could not measure the units.
So they are very sensitive IMO
But nothing is dripping,
I have a container wired under the taps in the bathroom (thank god the people arent there)
They are dry, with tissue paper in them 🙂
There is on the meter a small cog, that turns, this is what I am gauging this all on, the numbers go up (dunno what the hell they are, though)
It's a tricky one all I can sugest is to seperate in to circuits and pressure test each leg
And go from there
And go from there
Which has already been done, several times, with the same results (they are allready on seperate circuits, with isolating valves, which are new)
No i mean isolate the house once pressurised from valve no1 with 2&3 open so you can see if there is a pressure drop at all
I havent got a pressure gauge, but I can have the tap connector disconected and see if the level drops (using a clear hose)
When I shut off valve no 1, wait 10 minutes, then listen for a rush of water, there isnt one (using a listening stick)
Any more suggestions for when I return tomorrow to try ?
No your not getting what where saying disconect all valves and pressure test all legs inside the house with the appliances disconected and all pipes stopended
Put a pressur gage on and put upto about 3 bar and give it an hour or 2
You have sorted that once the stopcock is off no water passing
Reply to the thread, titled "A real brain teaser, its got me beat" which is posted in UK Plumbers Forums on Plumbers Forums.
Derrick229,
Dan,
