kennedy1978mark
91
sunny manchester
Heating Engineer (Has GSR)
hi , can anyone pls tell me what i need to know off the top of my head and what is acceptable to revert back to viper book ,in acs assesment .. assesment next week and i ve not stopped reading the viper book.. (took a week off work and been reading for weeks!!) but i just want to know if theres any areas which i should really concentrate on .. also any help what so every would be really appreciated so if any tutorials available etc etc please forward ...dont want to be under prepared and have to be reassesed ...many thanks mark
If it's tour initial ACS. Don't panic over your first attempt at any of the exam papers. You cab get 30% and they will give the paper back
So for my initial. I rushed through the paper on first attempt so not to waste anytime. And when they gave the wrong answers back to me I had more time to reference the questions I had wrong
Sent from my iPhone using Tapatalk
you can fail 1st time if you dont hit at least 70%. i am surprised centres are allowing students to pass with only 30% right. if your trying to guess the answers, whats the point of training, you wont know it when you leave, the the gas man could take your acreditiation from you
Best tip I remember is to take your time and read the questions carefully, on the front cover of the exam it will tell you the BS and reference documents you will need. Put the rest away, that way if you cant find something you will only read through the documents that are relevant to that exam paper.
i work in a bpec centre and candidates MUST get at least 80% after SECOND attempt at each theory exam, then they get oral verification questions on the wrong ones, to reach the 100% required, if less than 80% after second attempt then a resit is required, so technically you can get them all wrong on the first attempt, i would advise read the question CAREFULLY AND QUICKLY if that isnt too much of a contradiction,
first thing dont panic,just keep reading the viper book dont over do it only half hour at a time,your be suprised what you remember when the question comes up,read up vents,flues,fires.Your be all right good luck
i've got some mock question papers that are written in a similar way to the assessments, send me a PM with an email address and i will send them on to you
J
2K
Central Heating Forum
Deleted member 120897
