Seen 6bar static pressure reduce to 0.6bar dynamic pressure along with the sort of flow you would expect from 0.6bar.
Not the greatest pic, but hopefully gives you an idea of the boiler - the hot flow is only 2 l/m less than off the cold mains, I doubt it is the issue.
Those valves supposed to be closed guys?Not the greatest pic, but hopefully gives you an idea of the boiler - the hot flow is only 2 l/m less than off the cold mains, I doubt it is the issue.
Yes you can increase the pressure, as I said your boiler is rated at 5 bar, stick below that and you'll be fine.
And no those valves aren't supposed to be closed, but then the hot feed coming from the top of the heat store should also feed the boiler through a blending valve mixed with the cold main. Whoever installed the boiler hasn't finished it.
It's rated upto 5 bar, the boiler, flue gas recovery and heat store all come together. The heat store is pressurised by the heating water not the mains, it has a coil going through it which comes off the flue gas and back into the cold feed to the boiler, at least it should do but as I said, it's not finished. And I just want to point out to you again that I don't disagree with anything your saying and op has gone the wrong way about reducing his flow rate but for the sake of adjusting the pressure and how long it will take it's worth a try.If that’s a heat store then what pressure is that safe up to??
Seriously though test it in various places you’re plunging straight in with what isn’t the answer and will not be told
Take a picture of the stop tap and pressure reducing valve.What would you test first? If it isn't the PRV what do you think the issue is? The pipes were tested and cleaned prior to installation.
