View the thread, titled "Advantages of Direct Heated cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
L
LeakyNick
Hi
I'm looking at a thermal store which gives mains pressure hot water. The store will be heated by a solid fuel burner and a gas-boiler. I could have two coils put in the store (one for gas, one for stove) but I could also do-away with one coil and (say) have the stove directly connected to the store's fluid. Are there any advantages/disadvantages of going direct with one of the heat sources, instead of having two coils?
Leaky
Hi
Leaky
I would have them both direct, If the gas boiler is a condensing boiler it will be more efficient as it will have a lower return temperature which is better.
Speak to the thermal store manufacturer for advise, I use Newark Copper Cylinders and are very helpful. DPS are also very helpful but pricey!
Eco
Thanks Eco. I will speak to Newark but if I go direct heating, are there any disadvantages in having the return (say) 12" from the bottom of the tank? Basically, I'm doing a solar install and the woodburner isn't powerful enough to heat the entire tank so I'm wondering about convection currents being a problem if the return isn't at the bottom of the tank.
Leaku
Leaku
Newark will build you one to that spec. but normally for solar the bottom of the cylinder is solely for the solar anyway and everything else is taken above that.
The convection currents are not a problem from any input or output on the cylinder.
Eco🙂
Cheers. Thanks for the info.
Leaky
Another question that has arisen.... as I'm changing the old vented cylinder for a vented thermal store, should the old cold-feed cistern be changed for a smaller F&E cistern, or is it OK to leave-as-is?
Leaky
Leaky
Leaky
You get quite a lot of expansion with a thermal store because of the extra water content in the system, if the old cold feed cistern is in good clean condition it would be ok to use this
Eco
Thanks Eco. Would the system run OK without some sort of corrosion inhibitor in it, or should some be added?
Leaky
Leaky
No you need inhibitor and for the increased water volume you need to add more than a standard system
I've used both but I prefer newark and are cheaper, more helpful and to the same spec
Sorry can I butt in and ask how is it vented yet provides hot at mains pressure?
Reply to the thread, titled "Advantages of Direct Heated cylinder" which is posted in UK Plumbers Forums on Plumbers Forums.
