Dear all,
I have the following setup at my house for past 15 years.
1: Oil fired 35W Firebird boiler with flue in Garage ground floor
2: Convection based HW system with non-pressurized Cylinder which is fed by attic cold water storage tank . Only a Pleger Thermo mechanical valve with mercury tube as flow control to cylinder HW coil.
3. Pump comes ON along with burner as CH is switched on / does not come on when only HW is switched on ( convection )
4. Apparently, the hot water cylinder, first floor, is too far away from boiler....
Added for advise ( pictures ) later
Plan : advice required for Conversion to fully pumped S-plan regarding :
1. Plan to use 3 Motorized valves e.g V4043H , one each at CH supply separately , upstairs & downstairs and one at HW supply
2. Do I need an automatic bypass valve like DU144 ? Where would I connect it
3. Do I need to Take out the mechanical Pleger thermo valve from the HW system at cylinder entry
4. Should I also replace the 15mm pipes afterwards with 22mm which are plumbed for only 24 Inch run close to HW cylinder , tapped off the 22mm coming from boiler
5. Any safety issues as the motorized valves can fail during their service life
ANY HELP WOULD BE HIGHLY APPRECIATED
