Advice on making this connection..
View the thread, titled "Advice on making this connection.." which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hello....it’s nice living in France...apart from the plumbing...I need to connect to the chopped pipe....the pipe in front will be removed...I think I can solder it...just...any hints or tips ?
I want to avoid concrete bashing...
At a glance, hacksaw blade, file and a compression fitting spring to mind. What does it carry and where is it.
You may need to bash concrete.
Thanks for reply...
Under shower tray...hot water....not sure I can solder as access is tricky..will try compression and push fit and if not enough room solder and if that fails out with the power chisel...I challenge anyone to find anything worse than French plumbing...electrics are worse..
Reply to the thread, titled "Advice on making this connection.." which is posted in DIY Plumbing Advice on Plumbers Forums.
Le Rouret,
chrisW50450,
