Advice on plumbing qualifications
View the thread, titled "Advice on plumbing qualifications" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mike Parkin
I completed a C&G 6129 technical certificate in plumbing around 5 years ago as a mature student. From searching the web i understand this qualification no longer exists and i am now pursuing a career in plumbing.
I am aware the 6129 wasn't an NVQ and so wouldn't be accepted as a qualification by an employer. Can somebody please help answer:
· What is the current entry level qualification into plumbing I.E. NVQ2
· Would I be able to fast track the class room side of the qualification based on my 6129 experience
· How quickly could a semi competent individual with experience of domestic plumbing renovations complete the required NVQ
· Would I require a CSCS card, or current equivalent in order to undertake work with an employers
Any responses are very much appreciated
Chris above will be the man , but from what I know NVQ 2 is sort of qualified within the industry .
But the full and recognised qualification is NVQ 3 .
NVQ 3 doesn’t actually have to include gas , or it didnt .
Hi Mike, I will have to check with a colleague tomorrow on a couple of bits & get back to you but can tell you these.
To be recognised by larger employers for site work you would need to hold a Level 2 6189 NVQ as a minimum but even with most will test you out in the field to see if you can walk the walk.
Given access to the right kind of working jobs which allow you to prove competency & providing an accessor can come see you, not long at all, couple of weeks for Level 2.
If you are aiming to get on larger sites they would require you to have the trade one yes. The safety theory part should not be an issue for you with a bit of a bush up on the stuff you did it the safety unit on 6129.
I will need to check there is a route if you have been working as a plumber / mate, I will get back to you.
Thank you for the swift response. Very helpful replies. I'll be approaching some potential employers soon as I'm taking voluntary severance at end of March and would love to do plumbing full time with the aim getting into gas also.
Thanks again
Reply to the thread, titled "Advice on plumbing qualifications" which is posted in UK Plumbers Forums on Plumbers Forums.
Mike Parkin,
Mike Parkin,
