L
Lorna
Hello
I had some work done by a plumber today but I am not satisfied with the job
I have a Glow Worm FLEXICOM24CX system. When it was installed I had radiators in all the rooms downstairs and two upstairs. I have had it about 5 years and decided to have the radiator in the hall put upstairs in one of the bedrooms and have a bigger radiator put in the hall. I first had the boiler serviced and said what I would like doing with the hall radiator which the plumbers said would be fine.
I had already told them when they serviced the boiler that the radiator in the back room downstairs was not heating up as it should and that I had bled it and just water,not air, had come out.so they said they would drain the system when they came . They did that and did the job with the radiators as planned. When they finished the work and the radiators were put back on some of them were not heating up as they should and they said they hadn't opened ' them properly and did them again. They then said that they would be alright and give them a few days. They then said that the ones upstairs should only be turned on halfway as they were taking the water from the downstairs ones...I was getting rather fed up by this time and was quite upset because my heating was not as I wanted or expected. I expected all radiators to come on full when they are turned up full (all at once) but they are not!!!!!
I will be calling them back (hopefully they will come) so was wondering if any of you can tell me what to say to them if it is still not done to my satisfaction. Not too much to ask is it that all radiators are working properly?
Thanks for any advice.
:smile5::smile5:
:smile5::smile5:
