Hi guys
Last week I carried out what I expected to be a small task, replacing a bath/shower mixer at a flat which has a combi-boiler. As there was no isolation valve on the cold supply to the bath I had to turn off the supplying stopcock. Unfortunately, what transpired was that the cold supply to the bathroom was fed from a cistern located in a loft in the top floor flat of the property. Anyway, I drained the cistern and carried out the work as well as installing a valve on the pipe. Of course, as careful as I tried to fill the cistern I ended up with an air-lock. I now required access to the loft area which was not available as the occupants were absent. I tried covering the mixer outlet with my hand and opening the hot supply but it was unable to shift the air in the pipe. Eventually I was able to borrow a spare key from another neighbour which allowed me into the flat and loft. Even at this stage access was miniscule and it took some while to establish which cistern served which flat. Despite several attempts to blow water down the distribution pipe it took a couple of hours before the air-lock would shift and water would run through the pipe to the bath.
So what should have been a job normally requiring 1 to 2 hours to complete ended up taking most of the day for reasons outside my control. Now the customer (who lives elsewhere) who I have invoiced has kicked up a fuss because of the time taken and obvious extra cost.
I need to respond to this forthwith, but I have question that you might be able to advise on. Though the said pipework configuration arrangement flies in the face of ‘good practice’ from a common sense viewpoint, is there technically any breach in Building Regs having a CW cistern supplying what should be from the mains? I have had a quick browse but can find nothing relevant.
Any views much appreciated. Thanks. :smile:
TBW
TBW
