Hi all - need to know which pipe is hot water out of my gravity fed hot water tank please - have horizontal two pipes out at the top and one vertical pipe 🤔 roof is boarded so struggling to trace to the tanks 😔 thanks in anticipation 👍🏻P0
Can't say without seeing it. If this is a tank fed/open vented cylinder, then the pipe off the top will be a supply to the draw off points and a vent over the tank above.Hi all - need to know which pipe is hot water out of my gravity fed hot water tank please - have horizontal two pipes out at the top and one vertical pipe 🤔 roof is boarded so struggling to trace to the tanks 😔 thanks in anticipation 👍🏻P0
Picture ?
Hi there- the hot off the tank has a vertical vent back in to the cold water tank in the roof - any help would be greatly appreciated as our plumber is saying he doesn’t know how to do it - said if he puts a boost pump on the hot will it just boost into the tank in the roof ? ive Spoken to the pump manufacturer and they said it won’t thanks GraemeOn way this morning 👍
