ARCHOVED Magic Heating Box - Magic Thermodynamics Box
View the thread, titled "ARCHOVED Magic Heating Box - Magic Thermodynamics Box" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Yes, I'm from near Cremona and was exactly the distributor that called me to check the system and understand if it's a scam. The cost of about 3000€ is just for the box without the set-up of the plant.
Sorry, I don't quite understand you. Are you saying that Universal Connections from Cremona asked you to attend a presentation by Tim Cremlin, and give your opinion?
Yes, I attended a presentation by Tim Cremin and Universal Connections asked me my opinion
Hi guys I actually a attended one of theseseminars at Chelmsford to look at the heating management system and to behonest was very skeptical, after the presentation It made sense but I couldn'tget my head round it as it in theory defies the laws of plumbing as we know it.I asked if I could see an installation and if there was any work as I wouldlike to complete some installs myself. They were very helpful and I was out onan install for site training the very next day, as crazy as it may seem the systemwas fantastic, the complete radiator heated up within 20 mins on a 16 radsystem, the delta T was reduced to 3 degrees which I did not think waspossible. consequently I have know installed 10 of these systems which I canassure you have all improved the customers heating, I actually went back to twoof the customers to see how the system was performing as they were local andthey have noticed a significant change with theincrease speed with the property heating up performance of the all radiators (all being the same temperature) and the boiler running for less time thannormal. One of the two customer has actually turned there room stat down from21 to 19. I really think this is going to take off.
Hi Joshua
Forgive me for being cynical, but can you prove that you are a bona-fide heating engineer, and not just an internet shill? For example, can you give your Gassafe registration number, or a link to your website?
Its not the laws of plumbing that concern me, its the laws of physics. I don't mind contradicting a plumber (do it all the time!) but when it comes to contradicting Isaac Newton, I come over all shy.
Watch the oil installation video, its a low loss header with a pump for the boiler to low loss header and then individual room/cylinder stats linked to each zones zone zalve and its own pump, totally useless if you only have CH and HW zones. The heat up times could only be measured against a system with an undersized pump. As for the radiators its obvious thats just the power flush.
The programmer is well.....just a programmer!
Saving money? How by running three pumps instead of one....
Hi Ray not an internet shill, just been on the training , completed 10 installs and impressed with the results. Was Googling looking for other installers of the heating box and fumbled across site, seems no-one on this site has installed one yet and thought the feed back would be useful.
Thanks Joshua. Are you an experienced heating engineer by trade?
I would like to think so been completing general building works and plumbing for 16 years now, I have had experience installing A2W systems Samsung LT and Daikin HT and Thermo dynamics. This one interested me as was a product that actually improves the existing system rather than installing an alternative.
You don't want a 3 degree delta T. Reducing it will stop a condensing boiler condense to get this value the boiler must be way oversized. These amazing rads, had they been power flushed?
The guys and girls on this forum are way too wise to fall for this. Next thing you will be pushing is hydrogen generation to improve fuel economy in your van..........
Hi Erpkid from my understanding boilers condensate when the return temperature is under 55 degrees, on one of the systems I installed the leaving flow temperature from the box to the rads was approx 55-57 and the return temperature 52-54. The leaving temperature from the boiler was on 60 as part of the kit is placing a pipe stat on the primary flow pipe from the boiler, this is because the system is not as efficient running over 60.
yeah I was cold called too but glad I went to the seminar as found it interesting and ended up completing some installs which has been good.
Stick me down for two then 🙂
complete nonsense.
If this technology was real then worcester/vaillant/baxi etc would have been all over it like a nasty rash.
Hi Joshua.
Thanks for the reply. With respect, general building work and plumbing is not quite the same as being a heating engineer. I'm not trying have a pop, but that could mean tarmacing drives, building extensions and fitting kitchens.
Can we just take a quick wander through the physics and practicalities of central heating efficiency? Forum members feel free to chip in and correct me if I go wrong or miss something.
We start with the calorific value of the basic fuel.
In a perfect system, all this would be used - but as we all know, there ain't no such thing as a perfect system. However, by Newton's law of conservation of energy, you can't get MORE out than you put in.
So in no particular order, we have inefficiencies in the system that mean we don't get 100% of that potential.
Losses through imperfect combustion - pretty minimal in a well maintained gas appliance
Losses via hot flue gases - still real, but minimised by a condensing boiler and a well designed system
Losses via the fabric of the building - still by far the most common inefficiency, and best tackled through well understood insulation methods
Losses caused by heating the wrong space or at the wrong time - again, quite common, but best tackled through zoning, TRVs, roomstats and timing controls. Commonly fitted, but often not understood by the user.
The most cost effective way to save energy for a householder is to read and understand the instruction book that comes with the controls - turning TRVs to low settings in unused rooms, programming the system properly, turning down the roomstat (and locating the roomstat correctly). If modern controls are not fitted, they are probably the best investment.
The next most cost effective (if not already fitted) is to upgrade insulation.
According to this article the average cost of heating a home is £587 a year. (Less than half the total average energy bill - the remainder going on lighting, cooking, hot water etc).
The very best that I can see the magic box achieving is a very marginal saving on that - lets concede (and I am utterly unconvinced) that it allows the system to run 5% more efficiently. Boiler manufacturers will completely re-engineer a model at the cost of £millions to get 1/2 of one percent, so I am being pretty generous here.
Do the maths.
Even if your house is huge, and you have a heating bill of £2000 per year (nearly 4 times the national average) and the magic box delivers a 5% saving (which I am acutely sceptical about), thats £100 per year. £1000 per decade.
In three score years and ten, a theoretical lifetime saving, assuming you owned the property from birth, of £7000. And thats without calculating the lost interest that would have accrued over 70 years if you had just put the installation cost in a building society account.
How much does it cost to install again?
Hi Ray I have installed these heating boxes, the boilers have been turned down from 75 to 60 and heated the homes adequately this is fact, as an installer the name hasn't really concerned me the improvement to the heating system does, have you looked at the concept of the heating box? was I correct on the way a boiler condensates? I have been installing these heating boxes and more than happy to discuss them but lets keep it professional.
Professional is a good term
There is a lot of good professional tradesmen and also a lot of professional conmen
You join and your first and only posts are to sing the praise of a system that your implying I'd an all singing all dancing money saving device
So if you can tell me what is the payback timeframe on these magic boxes
Can you point me in the right direction of any professional data that shows the running efficiency and also what is the patent on these as I'm sure if it was as technological breakthrough as is being stated then the inventors would want it patent protected against copy
Hi Ray thanks for speedy reply I am not selling this box just been installing them and have no idea on savings or pay backs, my comments were I have installed the heating box and the noticed the improvement on the heating system doing so, the boilers I have installed have all been turned down on their various dials and boilers have run for less time getting the rooms up to temperature, I have been impressed with the balanced heat over the complete radiators. Have you seen a schematic of how the heating box is installed?
Why don't you show us then!!
Keefy a bit aggressive I am just an installer not looking to attract abuse as I said to Ray I am happy to discuss my experiences have you seen the heating box ?
I'd love to see the facts too! Show us Joshua!
Trying to shift attention from your damage control exercise by implying a forum member is being aggressive towards you isn't working. Yes, I've seen the 'box' though not in person and have come to the conclusion that I wouldn't not ever use it or buy one.
Guys all I am asking is have you looked at the concept of how the box works and integrates into the system? what part of the heating box is it that you think doesn't work? I have installed them and sharing my experience which is what this forum is for.
So come on then give us the information if you can
They are basically a low loss header yes or no
It's not how good your system is designed
its about how you can prevent the heat lost
95% of customers DO NOT understand what a low temperature central heating system it's ! ALL they care about is RADIATORS to be REF HOT !!!and you that have been fitting them : its not clever coming here and telling plumbers about how good they are !!! You must need to have strong coffee and WAKE UP .
i was in the alps , ch did run at no more then 40 degree and house was at 20 all day long : how did they do it ??? They had 20 of your boxes installed , NOT !!!
They had triple glazed windows and Lots of internal and external INSULATION .
No we don't know mate. Tell us exactly how it works and exactly what the saving will be for the customer and at what cost.
Stan is spot on you can have the best heating system in the world but if the house is not thermally efficient then nothing is going to work
Keefy I have no you tube videos just install experience and a brief knowledge on how the concept of the box works. The negative comments do not effect me in any way shape or form but the negative comments are not based on the install concept of the heating box or proves its a con, I have installed them and it improved the heating system that is no con sorry to disappoint you and sorry it annoys any of you that I was positive about a new product I have been installing and shared with the group. Can someone please explain to me why they think the system doesn't work just to satisfy my curiosity, or are the plumbers here just want to make fun?
You are not a plumber !!! Take 10 min and read on this forum and you will understand ! How dd you install it ? How did you commission you system boiler ? If you don't answer in 10 min I can only assume you're not a plumber.
Then please share your brief knowledge on how it works
And yes a low loss header often works to improve heating but can knock a basic one up in 10 mins for less than £50 on a normal house pumps excluded of course lol
wow very inviting! not for me thanks not interested in abuse as clearly stated previously. looking at your number of blogs you have obviously have been on this site a long time and have a lot of experience. If you would like to word your email politely and constructively with some valid points I will endeavour to reply the same if not then not for me--and maybe this site should come down because on this thread no-one is interested in plumbing so I partially agree -- admin should remove the thread.
So I guess you can't tell us how it works then
Gray0689 is there any way to take to another forum or chat on one to one as some authors on this site are not really interested in my experience installing them, if you want to talk about the heating box and my installs happy to do so but not interested arguing unless its plumbing related.
Reply to the thread, titled "ARCHOVED Magic Heating Box - Magic Thermodynamics Box" which is posted in UK Plumbers Forums on Plumbers Forums.
Centralheatking,
Keefy,
