View the thread, titled "AT RISK WATER MAIN EARTH BONDING THROUGH METER BOX BACK PLATE" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Assuming it's outside the box, and it's going straight across the cavity, I'd be interested to know whether electrical regulations strictly require a sleeve? If not, then I'd suggest any common sense material (offcut of pipe or hose) would do as they would class as a cable installation aid.
right thanks, just with it being probably near the meter installation thought it would be for the best. cemented in place and with a good bit of non setting compound perhaps in the end. they suggested 20mm conduit on the electrician forum
20mm conduit or a bit of 15mm copper either acceptable
Thanks Shaun.
Today the company have replied to a recent initial email I sent with the photos saying:
"Hi,I have returned from annual leave this morning , I will investigate this and get back to you when I have more information. Are you happy for us to seal the wire? Thank you"
I havent replied with an alternative yet. Just wanted to formulate the best counter suggestion.
Cheers
Yep also it’s modifying the meter box technically as it’s not an approved hole so needs a new meter box and the earth moving externally or via an approved entry
I found this thread on the Electricians forum, I was not aware us sparks could not drill a hole in the meter box, but now I know, it makes sense. Maybe I'm the only spark that does not know this, but I doubt it. There is nothing in our regs, and we are the ones fitting the bonding, so the IET should include this in our regs so we don't continue to do this. But as commented previously, there must be loads of boxes that do not comply. Replacing the whole box seems over the top if this is the only non compliance.
Looking at the regs snip, it seems to me that the requirement is to make the rear part of the box air tight. I'm thinking a Wylex Membrane Cable Entry gland should be sufficient. I know the Wiska membrane glands are IP66, I assume Wylex will be the same. So this could be an easy fix ?
Problem is it has to be tested to be air tight tbh these days I don’t know why there isn’t a m20 threaded hole so you could put a gland in it etc
Yeah I agree, it’s all about proof.
M20 thread Sounds like the perfect solution.
I was just thinking we could just drill and use compression gland, but often the spark arrives after all done, so we could not get a nut on.
Although most import thing is education.
Hence why they drill a hole where they can get too it’s one of them needs more communication on new builds
External box tested air tight? Is this real? Our gas meter cupboard door doesn’t even seal properly😁
every day is a learning day.
shame the gas regs people and the electrical regs people cant agree on consistency of wording of regs 😊
Classic one is the new ones 18th am3 I think, if poly / plastic incoming yours doesn’t require to have sup bonding where as ours stat you must 😀
This day and age you would think they would get together and have a meeting
AMD 2
Yes, hopeless isn’t it
The muppets come up with electrical changes to justify new books, exams etc and they can’t even check they are understandable or logical. And they rarely correct earlier mistakes or errors.
With the 18th edition, the printed version was slightly different to the electronic version😁
The only opening in a built in gas meter box should be the outlet pipework spigot which must be fitted with the spigot adaptor to form a conduit through the cavity. Earthing should preferably be attached to the gas pipe immediately inside the property and the spigot sealed with non setting compound. No other holes are permitted in the box. The reason why of course is that such holes would permit gas leakage from within the box to enter the wall cavity.
Reply to the thread, titled "AT RISK WATER MAIN EARTH BONDING THROUGH METER BOX BACK PLATE" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
Joined
Location
Stockport
Heating Engineer (Expired GSR)
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
chris123,
Pssst,
