Bath Twist Popup Plug Not Working
View the thread, titled "Bath Twist Popup Plug Not Working" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi there,
My twist pop-up bath plug isn’t working and when trying to repair I’ve made a few daft decisions which have led me to the position I’m now in.
I first of all adjusted the plug itself by lengthening it using the screw underneath. This didn’t work, so I looked at the twist dial. I noticed the hole for the adjustment screw and seen the screw and rather than tightening it to see if that fixed it first, I tried to loosen it so I could take the twist dial cap off. The screw fell into the dial, and then the dial wouldn’t come off.
I tried using the backend of hammer to get it off and when doing so the adjustment screw fell out the dial and down my plug hole into the abyss.
I also couldn’t get the dial off using all my strength and even the fixing or whatever it’s attached to was starting to come away from the bath so I didn’t want to do this further.
I’ve took the bath panel off, no obvious problem with the cable connection however Not sure what to look for.
What screws can I buy to try fit and tighten the adjustment screw again, and if this fails do I have any hope of fixing this myself given I can’t get the dial off?
I don’t think the adjustment screw is the issue, as this went back to before when the dial still operately normally (dial turned on/off rather than 360/all the way round).
Any help appreciated, currently using my child’s toy to remove the plug.
Thank you from a complete noob.
  • IMG_4343.MOV
    15.6 MB
Reply to the thread, titled "Bath Twist Popup Plug Not Working" which is posted in UK Plumbers Forums on Plumbers Forums.
B Rodriguez,
Harvest Fields,
