bathroom extractor fan not doing its job
View the thread, titled "bathroom extractor fan not doing its job" which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
A
ajsoad
hi all. just finished fitting my new bathroom and for some reason the extractor fan isnt extracting enough of the steam out. the bathroom is only 2.7m x 1.9m. ive got this http://www.****************/shop/Electrical//100mm+Low+Profile+Extractor+Fan+Timer/d/sd/p71737 fan fitted and ive turned the dial to the maximum on it. the red square shows the position of the fan. also there is a trickle vent on the window. ive also tried removing the pipe from the extractor fan to check if it was restricting the flow but didnt make a diffrence. any ideas? or have i just bought a useless fan? details for the fan are
  • IPX4, 220-240V 20W
  • Wall or Ceiling Mounted only
  • Part F Compliant
  • Backdraught Shutter
  • Airflow: 90m3/h, 25l/s
  • Sound : 38dBA @3m.
Either it's a useless fan or the room is so well sealed that replacement (make-up) air can't get in.
Try a mixed flow fan, they're quieter, more efficient, better pressure handling etc.
We have a 9 inch kitchen fan in our bathroom, never rated those poxy 4 inch fans.
Clears the room a treat and will hold up a sheet of A4.
have you tested it with a piece of toilet paper? turn it on and put a piece on the face if it stays in place it is working maybe you are making too much steam?
no havent yet tried any paper on it. if getting the make up air is the problem what options would i have to sort that? dont really want to take any more off the door as ive taken more than the allowed 10mm off the bottom as it is. thanx
Well it's easy to test if make-up air is the issue, you'll notice a big performance improvement when the bathroom door is open. If it is a problem you could cut a hole in the bathroom door and install a stainless steel or anodized aluminum louver.
Reply to the thread, titled "bathroom extractor fan not doing its job" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
ajsoad,
marvoni,
