Ted808
372
61
28
58
Folkestone
www.planetplumbers.co.uk
Heating Engineer (Has GSR)
Hi Guys
Can I wire in a bathroom extractor?. Cables are in solid ceiling. Can only access cord pull for light and light fitting- seems like there's L N E in the light fitting and L SL in the fitting - the fan has a timer I think I got the wrong one.
Cheers ted
  • :willy_nilly:
I'm not sure but bathroom electrics used to be 'notifiable' and as such the person doing the work or certifying it needs to be suitable qualified and certified.
Just be aware that if it is notifiable, you DIY it and you have an electrical fire your insurance company could invalidate your insurance!!!!
Be very careful.
Hi Guys
Cheers ted
  • :willy_nilly:
You should have L Ls N E on your light fitting. Take a 3 core + e from there to isolator (check if required by manifacture) then from iso to fan.
If 230v fan is fitted above bath or shower then it must be above 2250mm or be 12v
No it is not notifiable work. A minor works cert is recommended.
Good luck
Hi Guys
Cheers ted
  • :willy_nilly:
Good luck
Good luck
Thanks I think I'll get a sparky as soon as you say switch live my brain goes bzzzzt!
L
Bathroom Advice
Chainsawcharlie
C
