Jan 28, 2019
19
DIY or Homeowner
I'm in the middle of refurbing my bathroom, I have removed all the plasterboard, back to the stud work and also lifted up all the chipboard flooring (22mm), this is a small ensuite bathroom (3mx2m). My plan is to fit new flooring, 18mm WBP and then 6mm Hardie backer board to the floor, planning to tile on top, for the walls I plan to use Jackoboard in the shower area and moisture resistant plasterboard for the rest of the bathroom. Do I need to protect the plywood which will be under the hardie backer board and also would you fit the shower tray over the Hardie backer board? or on the ply only and fit Hardie backer around the tray. thanks
