K
Kev the gas
Afternoon all, I has a quick look at a Baxi 80 he plus this morning.
the boiler keeps going to fan lock out. The boiler does try to spark, for approx 3 attempts then lock out.
The fan does not run at all, the baxi mi suggest fan.
Before I order a new one any other suggestions.
There is a clicking sound from the pcb as well
Thx
Kev
Thx
Kev
Kev did u try spinning the fan impellor manually just incase its stiff. (Or can u not get access) was there power going to the fan??
Reactions: 3 people
Check you're getting voltage to the fan. Check the resistance through the coil. Also as kris says, check to see if it's just stiff, it may just need the bearings lubricated.
Strange how it starts to spark mind, it shouldn't go to ignition until the fan has been proved, so maybe check that the APS isn't stuck in the closed position.
Reactions: 4 people
