G
greville
Hi, got home from work last night and boiler was showing fault code E158 (condensing discharge fault). Have had a look in the boiler and there is a small pool of water in the bottom of the boiler so I have taken the condensing pump off and the bottom of it appears to be warped and not sealing around the impella housing. Have seen other post saying that there is a problem with the pump fitted to this boiler and was wondering if this is it? Has anyone else experienced this problem any help/advice would be greatly appreciated.
