Baxi Bermuda PW5 Gas Fire Problem
View the thread, titled "Baxi Bermuda PW5 Gas Fire Problem" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Hi all, i have the above gas fire with back boiler.
The boiler is working fine but there is a problem with the fire after first light of the cold season(cold according to my wife).
The ignition has always been tempramentel so we have always used a "clicker" gas igniter.
We press the knob down and turn it to ignite position light the fire and hold the knob for about 10 seconds, release and the fire is lit.
The problem now is that we do the above but when we release the knob the fire wont stay lit, it just goes out.
I have tried holding the knob down longer and longer and longer but it just wont stay lit.
Any ideas please?
Hello, you need a gas safe registered engineered to repair it. Gas appliance advice to repair, won’t be given out unless you’re a proven engineer.
Sorry
Hello. It is a safety device that has failed, at worst. Cheap part, even if the full assembly is needed. Also easy to fit, no more than 1-1.5 hours work in it. When did you last have it serviced?
Thanks for the advice guys.
I have no intention of repairing it myself, not going to mess about with gas.
Just wanted to know the seriousness of the problem.
Do you have a link to the part required?, if cheap i want to buy it myself for the engineer to fit if possible.
Thanks again.
I recommend you don't do that without the prior agreement of the GSR who you want to fit it. GSRs will often refuse to fit parts bought in advance by customers ("It was really cheap, I got it on Ebay.") because they need to be certain that what they are fitting is right and in good condition.
9 times out of 10 it just needs servicing & no parts required. If it does need a part then it is only a consumable and will not cost you the earth. So have it serviced by a local GSR who has fires on their licence. That is all the advice you will get on a public thread I'm afraid. Good luck.
Reply to the thread, titled "Baxi Bermuda PW5 Gas Fire Problem" which is posted in Gas Engineers Forum on Plumbers Forums.
jaytwo,
Darren Jackson,
