bert large
404
152
43
Plymouth
I have read several times that the Baxi Duo Tec Mk 1 is a direct replacement for the old 80 E & 105 E which I can understand as it uses the same jig & pipe centres.
What I am unsure about however is what happens with the flue. The old 80E/105E had a centre line flue whereas the Duo Tec's flue is offset to the right.
Is there a special adapter available to bring the flue back into the centre or does a 90 degree flue elbow do the trick ?
Cheers.
Thanks chaps. Just interested to know how to overcome the problem. I installed quite a few 80E & 105Es, most are still working but all are over ten years old now & a few are starting to look a bit ropey. It would be a shame to rip everything out if there is an easier retrofit option.
T
