samdsparks
Evening,
Recently attended a customers house with a broken Baxi Solo HE24, ignition failure and fan squealing like a pig.
Fan removed and full of water, burner full of water too and central insulation panel soaked. No constant leak of water so heat exchanger believed to be OK. Baxi suggest its the flue seal between flue and top of heat exchanger but I can't understand how if this has gone it would send condensate to front of boiler instead of rear where it should go and fall into sump and trap?
Ideas welcome, at present a new fan is needed and burner, will chuck in a new sump seal too and it may need a new gas valve if water some how got in hear too however all this will get it working again but I'm no closer to finding out why there is water in the burner?
Sam
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
