Best £750 Aquataps or £2000 Quooker Tap £1000 Verana Tap What's Best?
View the thread, titled "Best £750 Aquataps or £2000 Quooker Tap £1000 Verana Tap What's Best?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dan
Administrator
Staff member
Admin
£750 Aquataps or £2000 Quooker Tap £1000 Verana Tap - Which is best?
Been looking online, and see adverts on TV, for a Boiling Water Tap.
Aquataps do them, Quooker Taps are probably the first to do them, and then there is a Verana Tap (I think it was) too.
Has anybody had experience in installing these taps? Can they hook up to existing plumbing systems or does it need its own feed?
How do they work?
Aquataps or Quooker Taps - Which is best?
Quooker Tap - Instant Boiling Water Tap
There are some crazy numbers there by Quooker!
Quooker I believe is the only one that actually has boiling water the others will be just below. Quooker should only be about £1250. Adding to this we have a Quooker it was fitted with our new kitchen, and has been great. Can’t speak for the others.
Have I got this right, for the Quooker tap to do all it's supposed too it needs a boiler, CO2 cylinder and a refrigeration unit installed and obviously a power supply all in the cabinet under the sink?
I think thats the idea. Not sure you would be installing that under a traditional sink I think it'd need at least a double cupboard so what's that 1200mm wide? Think it would fit under one of those?
Does all fit in a normal sink unit as it uses same CO2 bottle as a soda stream.
No way as if it uses small co2! How big it the boiler part?
Reply to the thread, titled "Best £750 Aquataps or £2000 Quooker Tap £1000 Verana Tap What's Best?" which is posted in UK Plumbers Forums on Plumbers Forums.
Dan,
Gasmk1,
