Best fix for a pipe repair on a bend?
View the thread, titled "Best fix for a pipe repair on a bend?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hello!
Only myself to blame, using the jigsaw as I was taking up the bathroom floorboards and the one board I didn't look under ... Had the H&C feed.
If it was on a straight I'd be quite happy to use these copper patch repairs but as the cut is on a bend I'm assuming you don't get an adequate seal.
What is the recommended fix for this? I don't have a pipe bender so from a cost perspective would prefer to avoid removing and replacing but if that's the recommendation I'll have to make the investment.
You’ll probably have to either get a coupling and bend the pipe, or take the board up further back to try to ascertain what can be done. As a temporary measure (I do you need it) you might be able to use a rubber hose type make up and jubilee clip.
I think you want to keep everything in copper, soldered joints and minimise their number. If you don't own a pipe bender you can rent one from a tool hire place. If you aren't experienced at soldering, bending pipe, etc. get a plumber to do it for you.
If you finish cutting that pipe where you have and prep the ends you might have enough meat and it is straight enough to solder in a slip coupling. You have two joints there in near vicinity that you could nick a bit of length from if you need it...not what I'd do professionally of course.
That is the route I'm thinking, two elbows and then a straight coupler. One more fitting than trying to bend to replicate but a lot easier for a DIYer. On closer inspection only the 22mm hot has an actual cut. I've nicked the 15mm cold but doesn't look like I need to change it
So I've turn the mains back on, run the taps for a bit... How long do you leave it till you know you've done it right?😂😂😂 In all seriousness, it's incredibly hard to tell if the solder has made a complete seal. I practised a little first but there is definitely a fine margin between right blow torch heat, amount of time to leave the heat on, when and how much solder to apply.
A bit more practised required but if it holds it holds 😉 ...if you apply solder to the back of the fitting you'll know you've applied enough when you see it flow and run around the top of the fitting to the front and complete the join.
Reply to the thread, titled "Best fix for a pipe repair on a bend?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Mjward,
Ric2013,
