Mar 3, 2020
168
29
28
West Yorkshire
DIY or Homeowner
Hello!
Only myself to blame, using the jigsaw as I was taking up the bathroom floorboards and the one board I didn't look under ... Had the H&C feed.
If it was on a straight I'd be quite happy to use these copper patch repairs but as the cut is on a bend I'm assuming you don't get an adequate seal.
What is the recommended fix for this? I don't have a pipe bender so from a cost perspective would prefer to avoid removing and replacing but if that's the recommendation I'll have to make the investment.
So I've turn the mains back on, run the taps for a bit... How long do you leave it till you know you've done it right?😂😂😂 In all seriousness, it's incredibly hard to tell if the solder has made a complete seal. I practised a little first but there is definitely a fine margin between right blow torch heat, amount of time to leave the heat on, when and how much solder to apply.
Reactions: Ric2013
A bit more practised required but if it holds it holds 😉 ...if you apply solder to the back of the fitting you'll know you've applied enough when you see it flow and run around the top of the fitting to the front and complete the join.
  • Agree
Reactions: Ric2013 and Mjward
