Sep 14, 2018
essex
Other Tradesman
Had a Maxi Platinum combo fitted to old plumbing 5 years ago, the system was flushed and a inhibitor was added at the time.
I now need to add another radiator so as I'm draining down what's the best inhibitor/scaler to use.
I have a water softener in the house and the boiler has a Adey magnetic filtration unit fitted (which is cleaned out annually).
Sentinel inhibitor for me. As your'e doing works, why not give it a flush?
  • Agree
Reactions: Pickwickpick
1 bottle of x100 will be fine for 10 radiators. I presume your water softener feeds your boiler, just remember you can't fill the boiler with artificially softened water so unless you have a filling loop which bypasses the water softener, you will need to shut off your softener and open the bypass valve, run the hot tap for a couple of minutes to flush any soft water out your system, and then you can fill your heating back up.
Didn't realise about the soft water, believe it was filled when installed with soft water. I guess I'll need to flush though anyway now and refill with the soft water unit bypassed. Thanks for the advice.
