R
Robomonkey
Hi all
Ive got two pipes to cut off to insert t's, but the pipes as they stand are really messy with large drips of solder.
I've got some emery cloth which with some elbow grease will remove the solder, but I intend to use compression fittings once I've cleaned the pipes.
I'm worried however that ill remove too much copper to get a good joint, is this possible? What's the best way to do this?
