Hi all
Sorry for the long title but thought best to bung all these questions together.
I'll be fitting a new kitchen sink soon and am unsure on the following...
1. Compression vs Push Fit for outside? I know solvent weld is the preferred and professional choice, but I'd really like to be able to dismantle every so often and clean out the pipes...
2. Which pipe for outside? If I'm using push fit then I guess the answer is obvious! but if using compression I've read I can use either type of pipe. Which stands up best to the elements? And do both types need painting (have read various answers on that question)?
3. Do I need an AAV valve? I'm totally confused as to when they are/aren't needed. For context, the kitchen sink is not connected to any other wastes. And it is open ended , i.e. the open end of the pipe sits just inside the drain cover grate. EDIT - I should add. There is no AAV in the existing set up. However, in case it matters, I will be going from a sink and a half to a single sink, and I'll be adding a dishwasher where does was none before.
Any help would be much appreciated.
Many thanks for reading 🙂
