View the thread, titled "Biasi 28s hot water problem" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
DTG plumbing
Got a boiler causing head ache. Its a biasi RIva
28s. Hot water fires for about 5seconds then shuts down.
Heating is working
changed temperature probes
and checked plate heat exchanger,
Could be possibly divertor valve or pcb?
Any help is much apreciated guys 🙂
Heating is working
When you say you have checked the plate heat exchanger, what exactly do you mean? What checks have you done. What's the temperature difference across it?
Upvote 0
Best to check pump flow switch is lifting enough to start the sequence of events 🙂 Could be that it isn't! May be switch mechanism is stretched? Flow's restricted ... ?
Upvote 0
Flow seems ok mate. And pump runs fine on hheating so should be ok or hot watert
thanks for help so far
Worth checking anyhoo's IMO ... Never assume in my humble opinion but check! I've had a good few problems with them in the past on the ideal mini, they have a poorly designed return manifold, Does the pump runs but the fan doesn't ?
Upvote 0
Yeh your right mate. Well yeah the fan runs and the burner ignites but tthen shuts down after about 5 seconds 🙁
Upvote 0
Will more than likely be temperature probe.
This may help in ruling the sensor out.
Biasi Riva 28s NTC sensor part number - 164026
Aprox temp - 15c expected resistance reading - 15k
Approx temp - 82c expected resistance reading - 1.5k
Upvote 0
I'd be looking at both flow switched to be honest, pump and hot water ... They may be one of them dodgy? If the fan's kicking in then that would leave pump switch less likely but not ruled out. Best check their op resistance. Could be dirty?
Upvote 0
This may help....
Legend.....
Br = brown
B = blue
Bk = black
W = white
R = red
Gy = grey
Y = yellow
G/y = green/yellow
* - direct connection with the ignition and flame control device.
Upvote 0
Reply to the thread, titled "Biasi 28s hot water problem" which is posted in Plumbing Advice for Any Other Country on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
DTG plumbing,
Doodlebug,
