O
Oren
With a BlancoAlta tap leaking from the top joint, I removed the cartridge and applied a smear of Plumbers Silicone to the composite o-ring - which slowed the leak down, but did not cure it.
The instructions for replacing the cartridge in a BlancoAlta tap are straight forward and as I could not find one locally (Exeter) I have sourced a replacement cartridge from the importers. This cartridge is not a straight copy of the old one illustrated in the service manual or the one coming out of the tap - it is blue and with a redesigned o-ring assembly.
I had expected that a new cartridge would immediately solve the leak, but have been disappoint that it is actually worse than the old one with silicone applied.
The cartridge has locating lugs, so can't go in miss-aligned, so the only variable is how hard the top is screwed back down.
Before assuming a faulty replacement, has anyone experience of these and can suggest a cure?
