Blocked underground U Bend
View the thread, titled "Blocked underground U Bend" which is posted in Renewables on UK Plumbers Forums.
dttrinity
It seems that the U Bend in the trap below a rainwater downpipe is blocked and I can't get it cleared. I'm a real novice! Any help would be appreciated
get yourself a unblocking coil/waste coil etc. forget the correct term, its just a long piece of bendty metal that you can fit down most tight corners etc, as a drain rod isnt very flexible and probably wouldnt bend enough, you can find them at screwfix etc, for about £15 if i rememebr rightly
Reply to the thread, titled "Blocked underground U Bend" which is posted in Renewables on Plumbers Forums.
dttrinity,
dttrinity,
