Hi there, could anyone help me please.
I have assisted a freind to relocate a domestic oil tank from one side of his garage to the other, some 30 foot. We ran a length of 10mm plastic covered copper pipe and continued to connect it up with standard a 10mm olive into the tank valve and made the bend using 2 x 90 degree bends as the pipe had to return back on it's self. The problem is that all the joints weep slightly. My question is should any joints be sealed with non setting compound or should they seal dry? Is it down to cheap fittings? The other problem is that the shut off valve on the tanks doesn't. I don't want to disturb the valve as its been in there for years, can I put a 1/4 turn shut off vale in line using a couple of 15mm x 10mm compression fittings?
Thanks to anyone that can help.
