Boiler flue
View the thread, titled "Boiler flue" which is posted in Boiler Advice Forum on UK Plumbers Forums.
E4gas
I looked at a non condensing boiler tonight , the flue elbowed of the top along 300mm then dropped down the side of the boiler to another elbow to exit wall about bottom of boiler height . What's the regs on that if there's any . It was like a big S
its fanned ,check mi,s,it could be allowed,does not look right but until you have all the info you can not ID or AR it
2.9 FLUE​
The appliance has a multi-directional fanned flue system.​
The standard telescopic flue assembly length is from 127mm to350mm.Extension flue lengths available are from 350mm to 2500mm.An optional vertical flue kit to provide for flue lengths up to3000mm including vertical flue terminal.A terminal guard, Type K2, GC 393 553, is available from TowerFlue Components, Vale Rise, Tonbridge, TN9 1TB.Do not allow the flue terminal fitted to the outside wall tobecome obstructed or damaged.A kit for internal fixing of the flue is available separately.
Reply to the thread, titled "Boiler flue" which is posted in Boiler Advice Forum on Plumbers Forums.
E4gas,
Barry98,
