Boiler for large domestic premises
View the thread, titled "Boiler for large domestic premises" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I'll be getting a commercial guy to do gas side of boiler, nothing stopping me doing hydraulic side. I will post the conversation between me and technical when I get the chance. They have confirmed.it will work on a domestic S Plan, just need to find large 2 port valves lol
What size? Also look at amz valves and actuators
About 1 "1/2 at least, i seen some online a while back around £150. just gave an estimate for the job if they accept will do a more detailed surveyou.
So chaps my van decided to pack up today so at home now doing some estimates. Looking g through the gb162 brochure and found this... 20160609_115030.jpg
This is correct. There is so much confusion surrounding commercial gas it's untrue. I had a similar question and the following facts apply.
Firstly as long as the boiler is under 70kw ie not a commercial boiler then you can install it, note worcester product you are looking at is a domestic boiler but a large one and is based on commercial design so that's where people can get some confusion. I'm pretty sure also that worcester insist on putting anything above a certain size (I think it's 40kw but don't quote me on it) into a low loss header so as the boiler can keep up with demand.
The next and most crucial part. The definition of commercial gas work is NOT defined by the property type. I see sooooo many people assume this.
It is deemed by the supply size your working on at this property. If the volume of gas installation pipework exceeds 0.35m3 then you must hold commercial acs tickets...
So what I would say to you is when you survey the work you look at the present installation of gas pipework and work out volume. Is it correctly sized for new appliance? If not what size will it have to be and what will the new volume be. If it's getting pretty close to 0.35m3 I wouldn't take the chance.
I got a lot of conflicting info on this but got there in the end. It is definitely down to gas pipework volume and not the property.
The 50 and 65kw one's don't. Only if you use the RC35 control
Well yeah it will 100kw installation. I can see what your saying though.. What u need to remember is headers lend themselves well to multiple zones with high demand as u can separate out pumps. Instead of relying on the flow rate of one pump to do 20-30 rads
Can anyone tell me if you measure the heat input of a room differently (height) if using de stratification fans. Hard to find any info on it
Sorry to jump on the bandwagon but I have been asked to price up a huge house. It has 2 gas meters as one supplied the house and the other was for the original swimming pool heating, the are both u6 meters. I thought it was commercial but he has had quotes from other companies fitting 2 boilers in series for the hot water and ufh on the 1st floor from 1 meter and then a second boiler 50kw for the ground floor heating off the 2nd meter. I can't find anything that says this is either ok or not and Gassafe are there usual vague selves. Worcester who have specified the boilers seem to think it is fine on a domestic ticket as the volume and kW is under the requirements for each meter and the 2systems in the house will be independent from each other. It would be a great job but I'm sceptical. Any advice, appreciated
think you mean u16?????
Not only boilers - ALL gas appliances totalled up. If you have a 65KW boiler, and a 7KW hob, you're outside domestic scope.
only other gas requirement is 6kw for the aga, this is included in the proposed set up for the 50kw boiler downstairs.which is 1 50kw boiler and the the aga so 56kw, off of meter one then 2 X 30kw on the first floor from meter 2.
It doesn't feel right to me. My initial thoughts were supply and meter upgraded to u16 then have the heat requirements for the whole house calculated and the gas side completed by a commercial engineer. But then with a quite from a domestic guy stating the above I don't want to lose out on a job of this size of it does fall within my domestic scope. And yes if it doesn't feel right I probably should go with my gut.
How far are the boilers to the meter? The 50 will need at least 35mm and depending on the run will take it to commercial ditto for the 2 30s
I'm visiting the site on Monday to do a survey, so will get the distances and spec then, I think that your right and the gas capacity will be the issue.
Right, been to have a look and this is what people are quoting for. the 1st meter will require a 9m run including fittings. This is for the 2 boilers in series (Worcester 27 system), these 2 boilers will heat the ufh on the 1st floor and the hot water cylinders.
The second gas meter has a run of 6m inc fittings. This is serving the aga 6kw, and then 2 Worcester 27 systems in series to heat the ground floor radiators.
Is this actually possible, I can't get a straight answer and don't really want to quote, start and then find out I can't sign it off. I'm leaning more towards leVing it as it does seem odd with 2 meters even though the 1st floor and ground floor are separate systems. Any thoughts or help with the regs interpretations would be very helpful.
Reply to the thread, titled "Boiler for large domestic premises" which is posted in Boiler Advice Forum on Plumbers Forums.
GQuigley67,
ShaunCorbs,
